7 members (Gdads51, Otto Skorzeny, TexasA&M48Truck, 5cameo8, TUTS 59, Youngin' Tut 59, Gray_Ghost),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,116 Posts1,056,599 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | I thought my '53 GMC had been converted to floor shift, but upon closer inspection unsure. There are 2 small holes on top of steering mast with nothing bolted into them, but the trans cover is missing and I can see the shifter is mounted to the actual trans and it would see stock. it is a 3100 SWB half ton w/what I guess is stock 228. Valve cover is GMC and door plate says 90 horse. what is throwing me is shifter, it looks like metal T handle at top with a black button that doesn't push on driver side thumb, anyone have picture of stock GMC or Chevy floor shift for 4 speed? It's still all connected to torque tube and stock rear and atill 6 volt. Would say barn find, but it's woods find. We chainsawed and log chained/4 wheel drive to get some trucks out of the heavy woods. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | What ever it is it's not original... No T handles with buttons.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | " . . . looks like metal T handle at top with a black button that doesn't push on driver side thumb . . . . . . It's still all connected to torque tube and stock rear . . . "If the shift rod goes into the top of the transmission and the transmission is connected to the original torque-tube, it is most likely an SM420 4-apeed with an exotic shift handle. 4-speed with upon-rear u-joint yoke | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Is it possible he has a pre 1948 transmission in there with the reverse lockout lever? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If it has a pre-48 transmission, would it have to have a matching rear-end/torque-tube (weren't the earlier transmissions different lengths compared to the later transmissions)?
