2 members (RLB, Rusty Heaps), 88 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#938977 04/27/2013 9:29 AM
I thought my '53 GMC had been converted to floor shift, but upon closer inspection unsure. There are 2 small holes on top of steering mast with nothing bolted into them, but the trans cover is missing and I can see the shifter is mounted to the actual trans and it would see stock. it is a 3100 SWB half ton w/what I guess is stock 228. Valve cover is GMC and door plate says 90 horse. what is throwing me is shifter, it looks like metal T handle at top with a black button that doesn't push on driver side thumb, anyone have picture of stock GMC or Chevy floor shift for 4 speed? It's still all connected to torque tube and stock rear and atill 6 volt. Would say barn find, but it's woods find. We chainsawed and log chained/4 wheel drive to get some trucks out of the heavy woods.
What ever it is it's not original... No T handles with buttons.
Give me ambiguity
or give me something else
" . . . looks like metal T handle at top with a black button that doesn't push on driver side thumb . . .
. . . It's still all connected to torque tube and stock rear . . . "
If the shift rod goes into the top of the transmission and the transmission is connected to the original torque-tube, it is most likely an SM420 4-apeed with an exotic shift handle.
4-speed with upon-rear u-joint yoke
Is it possible he has a pre 1948 transmission in there with the reverse lockout lever?
If it has a pre-48 transmission, would it have to have a matching rear-end/torque-tube (weren't the earlier transmissions different lengths compared to the later transmissions)?
