| | | Forums66 Topics128,022 Posts1,055,269 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | I just picked up a '75 GMC G-30 cab and chassis dually. It used to be a motor home, but now has a 10' flatbed mounted. This has the 16.5" wheels on it. I want to find a set of six compatible 16" or larger wheels that will replace the 16.5 wheels when I get around to buying new tires for this. What fits? Will any '91 and earlier 16" one-ton dually wheels fit this???
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Maybe this Tech Tip will help. Big Bolt Wheels | | |
