7 members (Gdads51, Ponchogl, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, 1 invisible), 90 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
#93885 12/14/2005 3:45 AM
Junior Member
Junior Member
I just wired up a new wiring harness in my 1950 chevy, but in my haste of cutting wires out of my way,I didn"t pay to close of attention to what wire went where on the back of the key switch. In the diagram from the chevy duty harness directions they show 2 ways to wire the switch I still have the 6volt system with the floor starter. any help thanks doug
#93886 12/14/2005 6:07 AM
wynns55,
This might to obvious, or wrong, but I would think at least one wire goes TO the coil. If you have the 6 volt system you probably still have a generator. I am not sure on this either, but there might be a switched wire TO the voltage regulator. The supply side of the switch should come FROM the battery, meaning it comes through the ammeter.
Hopefully, before you burn your new system up, the resident electrical engineers will make a appearance and give us the straight poop. Did Chevy Duty not supply a comprehensive wiring diagram for your rig?
Stuart
#93887 12/14/2005 7:02 AM
Doesn't the key switch have terminals marked - bat, ign? Those are from battery to ignition (coil).
#93888 12/14/2005 8:27 AM
I don't think the switch really cares. It's just an on-off switch. If there was a start position, it'd be different.
1954 GMC De Luxe COE
#93889 12/14/2005 3:41 PM
GMCpanel,
I wonder if these switches have a accessory position, that would make a difference wouldn't it?
Stuart
#93890 12/14/2005 4:00 PM
My 59 has ING1 ING2 ACC BAT and one or two more
#93891 12/14/2005 4:21 PM
I
I Offline
A '50 should have three terminals... one hot and two switched. No Acc. position.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#93892 12/14/2005 4:45 PM
Inky05,
What would the second switched position be for? Is the switch turned in the same direction for the first switched position and the second switched position?
Stuart
#93893 12/14/2005 6:43 PM
I
I Offline
I believe it was only to split the load. It is a three position switch Turned one way it is on to both terminals and the key cannot be removed. Center is off. Turned the other way is on to both terminals but the key can be removed.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#93894 12/14/2005 6:50 PM
That is weird! It would be interesting to know the engineers purpose for doing it that way...sort of like the passenger side door lock.
Stuart
#93895 12/14/2005 6:55 PM
I
I Offline
I read somewhere that the old farmers didn't want to be bothered carrying keys around that they might lose.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#93896 12/14/2005 7:02 PM
Those darn farmers....what a silly idea! HEY, where the heck are my car keys?? I wonder if the young farmers were more organized!
Stuart
#93897 12/14/2005 8:19 PM
Ex Hall Monitor
Ex Hall Monitor
Where did you buy the harness? Do they have a tech support number?
#93898 12/14/2005 8:27 PM
sure makes it hard for someone to lock their keys up in the truck on my 52,, lock the passenger door from the inside, drivers side, you lock on the outside with the key,,,
Redryder pix
My Hotrod
#93899 12/14/2005 9:58 PM
Junior Member
Junior Member
The back of the switch has 3 posts none of which are marked. the directions from chevy duty has 2 options for wiring and both pictures show different configurerations I wired it up one way the truck started but it buried the amp needle in the neg.and the coil wired on the switch started to smoke unhooked battery quickley. thanks for your input. doug
#93900 12/15/2005 3:52 PM
Doug,
I think you might have issues other than the ignition switch. The coil wire would overheat and smoke only under a terrific load..almost a dead short. The ammeter might have been trying to tell you this! Sit down with a cup of coffee and study the wiring diagram, you might find something you overlooked. smile
Stuart
