1 members (klhansen),
90
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 33 New Guy | | New Guy Joined: Apr 2013 Posts: 33 | This project is still a little ways off yet but I'm bouncing some ideas around in my head and could always use some more input or a different point of view.
My 'High Torque' 283 is getting pretty tired and in need of some freshening up. I have a Powerglide transmission and what seems to be about a 4.10 rearend. My thought was that I'll probably need a .030 overbore and to go with an RV cam and maybe move up from the two barrel Rochester and use a factory 4 barrel intake and Quadrajet. I know the 283 doesn't need a very big carb but I don't think overfueling should be a problem. And I'll have the heads worked on too and move up to an HEI ignition as well. Does anyone see any problems with this combo? I'm not looking to make a racetruck but I would like to have a peppy and reliable daily driver with a reasonable amount of fuel economy. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I've never been a fan of PowerSlide trannys, except for high-horsepower drag use, but everything else sounds good. Those little small blocks are very happy at higher rpms. Good luck. If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
