10 members (Bill Hanlon, Otto Skorzeny, BarryP, mick53, rfs56trk, Nick in Manitou, UtahYork, NorCal52Suburban, Hanks custodian, 1 invisible),
113
Mod | | | Forums66 Topics128,136 Posts1,056,745 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | Can anyone supply the correct point gap, spark plug gap and timing for 52 GMC engine?? Engines stumbling when accelerating. Need some good help here. Thanks, don. Sorry. Its a 228. Original engine. Carb also just rebuilt. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | .18 is a good start for the points, 35 on the plugs. 0.12 on the intake and 0.20 on the exhaust. if you have a vacuum gage set timing to highest vac. you can get. if not time to the ball and go from there. buy a maintenance manual everything you need to know is in there. or check out www.oldgmctrucks.com | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If no one posts 228 specs, the 248 specs should be close (from Rob English's web site). | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | Jet, Sent an email with the tuneup specs from my Thompson Manual. | | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | | | |
