1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Hope someone will have an idea. Top hinge, top bolt, I snapped the head off the bolt. I drilled a hole and used an "easy out" to try and remove with a gallon of PB Blast and heat. Of couse all I have done is how stripped the inside portion the bolt screws into so the broken bolt and the inner part just turn freely. I have thought about spot welding the inner part where I can see it. Can I cut this away and weld a nut assembly in there? Any ideas?
John | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Try left hand twist drill bits
Sometimes you can get the bolt to back out while drilling
Start with the smallest drill that will grab then step up | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | If you have the access, and you have drilled the center of the bolt, keep drilling to the proper tap size, then tap it. If you drilled off center, sometimes you can keep drilling until you just kiss the original threads. Then use a drift (punch) to knock loose the remaining portion. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | If I am reading your post correctly the cage nut on the inside is now loose meaning no amount of drilling or tapping will remove it? Is this the passenger or driver side? If passenger side removing the heater or the access panel may allow you to grab it with vice grips or something. If on the driver side there is no access to it. You may be forced into replacing the area with one of the door hinge repair panels offered by many of the vendors. This is a tough one that has come up before, maybe someone who has lived through one will post. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | here is a good pic from woodys site ...pic... maybe you can drill a few spots where the nut is from the jamb side ...pic... , spot weld them to keep them from turning then work on the bolt. | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I actually used a few different ideas over the course of trying. I didn't know you could get reverse drill bits, next time I'll get a set. What I ended up doing is drilling two small holes on either side of the bolt hole and pushed two finishing nails into these hole which went through the cage nut, this held it from turning. Then finished drilling with a 11/32 bit and lucky enough I was pretty much centred, then used the tap to clear the rusted threads and the remaining bolt out. I will weld the the finishing nails in the two holes I have so the bolt can be removed again with out the cage bolt turning. Thanks for the picture DADS, sure helps to see what is behind what you're working on. Thanks for all the input guys!
John | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I will weld the the finishing nails in the two holes I have so the bolt can be removed again with out the cage bolt turning.
John I'd suggest if the engineers and assembly line wanted a nut that just sat there they'd of spot welded one there. There's a reason that nut is "Caged" and maybe a better answer is in applying a little anti sieze when you install the new one  KEEP LOOSE NUTS CAGED!!!!
| | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | What stops the cage bolt from turning from the factory? Since they are round, looking at the picture from DADS, is it a friction fit? I don't know how to stop it from turning. what do you suggest? Thanks, John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a 'cage nut' is a square nut in a square sheet metal cage, the ones in Woodies pic are weld-nuts, tack welded in place or flanged into the holes, you'll need to tack it with a mig or wedge it some how, like jam a sharp tool against it, or as said above, drill a hole from the face and put a pin in it
Bill | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | He said he has 2 nails that are kinda caging the nut so it won't turn. Sounds like a good idea, only maybe use something better than nails. My advice is to use some aviation permatex on the threads or 3M butyl sealer http://3mcollision.com/3m-strip-calk-08578-black.html, that should keep the water out of the threads,the permatex though would act like a thread locker as it does harden a bit when it drys out. That butyl is good stuff and close to what the factory used like around head light buckets etc.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | When I did my doors I wound up making making a cage and the nut. A bit of a hassle but setting my doors (for the third time) and finding final fit would of made swiss cheese out of the cage if I was pinning it. I've since discovered you can get the square nuts at BigBox and hardware stores...
| | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Thanks for more info guys. Caso, I am assuming the Cage nut needs to float a little so you can adjust the door? Sounds like I have rounded out the "cage". Could I reach in behind and pinch the cage back against the nut? This is the passenger side door. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Heres another pic from Woodys site ...pic... I don't think you want your nuts to float Solid nut, fine thread bolt, star washer. Good luck | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Thanks for the pictures. Like I said before, it's nice to see whats behind your work, to give you a better idea of what's going on back there. Thanks again. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | There is a difference between our two models which Woody's pic show well. On Mine it's a caged square nut. Those in the photo are not meant to slip. Different beast...
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Heres a pic from the assembly manual ...pic... | | |
