4 members (Phak1, dt235sd, NorCal52Suburban, Wayne67vert), 85 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
Bosch alternator label reads
0 120 489 882 993 part no I believe
K1 14W 65A 21 electrical description
070 903 023 E I do not know.
I am not installing in an auto so colors etc are not applicabe. It is being used on a demo unit ie make power with bicycle for use in school training.
What I need to know is how to hook it up. Which terminal does what? Not even sure if it used external regulator. Wiring diagram and photo would be great.
Thanks for help
Dan Bentler
Actually go on the painless wiring website and look at one of their manuals for any of their generic wiring harnesses. They give instructions on how to identify and wire the different alternators.
My 46 GMC on Photobucket
3B Offline
Hy leitmotif, I think the original application for that alternator was 1980 - 83 Volkswagon Vanagon, hope that helps.
That is an externaly regulated aircooled vanagon alternator. Here is a wiring diagram but it will not help much as the terminals use plugs for the reg.
B+ is output
D- is the charge light
There should be 2 or 3 more terminals that accept a plug to the regulator.
Ted
My ride but looking for a Deco Bolt for the wife.
3B Offline
Hy leitmotif and guys, my Bosch catalog lists that alternator as an internal regulator type. There are only two terminals to hook up to, as Toolbox said B+ is output connected to battery positive, and D or D+ is for the no charge light. Of course for there to be a complete circuit you will have to run a ground wire from the alternator housing to the battery negative terminal. I have never seen an externally regulated alternator with only two terminal connections, hope that helps.
