3 members (moparguy, 37 GC, Otto Skorzeny), 109 guests, and 2 robots.
Topics128,141
Posts1,056,779
Members48,454
#936525 04/17/2013 7:49 PM
I'm building a 51 3100. The engine is an ls-1. I purchased the fuel tank that goes underneath the bed. My question is what fuel pump for the FI/LS-1.I'm being told that the tank needs a baffle and sump? My tank has neither. What are my options? I know the AERO makes a pump/baffle combo for about $600.00. it requires cutting a hole in the tank to put this in. outside of cutting a whole what else?
V
V Offline
Interested in reponse I'm doing the same thing but I thought you could buy the tank ready to go with baffel etc in there??
Well, you never want to starve your fuel injection pump of the cooling properties of gasoline. That's why the preference is to keep it submerged by way of sump and baffles. But no one says you have to use the in-tank pump. You can also find an external pump that matches the pressure and flow requirements of your motor. It would probably cost you a lot less than $600, too.
1 Offline
I used a GM Fuel pump It worked out great for my 51. Im running GM fuel injection so it only seemed right. thumbs_up
It was around $350 for everything ( The pump cost $80.00 at the dealership) And I didnt have to cut a hole in the tank. It was a easy install.
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Part numbers?
R-Bo
1966 GMC 305V6 in the family
1 Offline
Google It....
It was around $350 for everything ( The pump cost $80.00 at the dealership) And I didn't have to cut a hole in the tank. It was a easy install.
Bad 51, my tank is just a little different from yours I don't have the 2 holes in the top just one. the whole in my tank is just 1.75" id.(inside) I can Google the pump to get the dimensions. Do you know what the inside diameter of the wholes in your tank are. And does your tank have baffles?
1 Offline
Yes it's baffled, it's also got a pump well and both of holes are 1.75" The tank I got came with everything.., the fill neck & billet screw on cap, mounting straps, fuel pump sending unit, and all gaskets for around $215 all I had to get was the GM pump. The whole install took about 2 hrs.
awesome thanks for the pump info !!!
