1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Bosch alternator label reads 0 120 489 882 993 part no I believe K1 14W 65A 21 electrical description 070 903 023 E I do not know.
I am not installing in an auto so colors etc are not applicabe. It is being used on a demo unit ie make power with bicycle for use in school training.
What I need to know is how to hook it up. Which terminal does what? Not even sure if it used external regulator. Wiring diagram and photo would be great.
Thanks for help Dan Bentler
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Actually go on the painless wiring website and look at one of their manuals for any of their generic wiring harnesses. They give instructions on how to identify and wire the different alternators. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy leitmotif, I think the original application for that alternator was 1980 - 83 Volkswagon Vanagon, hope that helps. | | | | | Joined: May 2010 Posts: 20 New Guy | | New Guy Joined: May 2010 Posts: 20 | That is an externaly regulated aircooled vanagon alternator. Here is a wiring diagram but it will not help much as the terminals use plugs for the reg. B+ is output D- is the charge light There should be 2 or 3 more terminals that accept a plug to the regulator.
Ted My ride but looking for a Deco Bolt for the wife.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy leitmotif and guys, my Bosch catalog lists that alternator as an internal regulator type. There are only two terminals to hook up to, as Toolbox said B+ is output connected to battery positive, and D or D+ is for the no charge light. Of course for there to be a complete circuit you will have to run a ground wire from the alternator housing to the battery negative terminal. I have never seen an externally regulated alternator with only two terminal connections, hope that helps. | | |
