0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Does anybody make motor mounts that can be attached to the frame to set up a 58-62 235 in a vehicle such as a 37 truck to allow use of the side motor mounts that are on a 58-62 235 with out using the bell housing mounts on the older Chev vehicles such as a 37 truck?
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I would guess they are similar to V8 side mounts and therefore can use a (modified) aftermarket cross member. Classic parts 79-405. May take a little "engineering" but you can do it... or this may give you more ideas. I don't know dimensions of 235 mounts and 37 truck frames. Don't know the tranny you are using but it will need a mount also.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Lots of options in the classic sections of their catalog. May require a little of the engineering referred to above. www.speedwaymotors.com/ | | |
