1 members (delky), 127 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
I'm looking at a 1993 Chevy truck heavy 1 ton. It has a 12' flatbed and it has 19.5 wheels 5/10 lug pattern. I want to put my 55 gmc 2 ton body on that chassis. My gmc currently has 9R 22.5 wheels. Big 6 lug.
So my question/concern is I won't find any tall tires for the 19.5 wheels to equal or come close to my current tire height. (36" 37")
So I'm wondering is the old dually 20" wheels that has the same lug patter....
I imagine I could bolt those old ones on the 1993 truck.
So if I can.. Are there tubeless 20" 5/10 lug rims? If there are can you get tires for the 20" rim that can come close to 36" tall?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
3B Offline
Hy beast54, there are no 5/10 bolt pattern 20" tubeless wheels that I'm aware of. After 1956 there were factory 22.5" tubeless wheels made for the whole truck line, but the 5/10 bolt pattern wheels were pretty narrow, and they seem to be extremely rare.
Good luck on that one. I am learning new stuff all the time here so it'll be interesting to read what others post here, but I think you are barking up the wrong tree.
As far as tires and their height for the 20 inch rims, even the 7.50 is usually a little more than 36 inches. Now, I'm talking "old truck" rims and tires here. Definitely tube type. Maybe the new custom styled 20 inchers would have a rim and (tubeless) tire that would work on the newer Chevy truck. I think some of them are quite large.
1942 Chevrolet 1 1/2-ton (G-506 Military) Panel
Short video
Longer video
Beast54,
Maybe I can help clear a few things up for you.
The 19.5" wheels and tires are tubeless type.
The 20" wheels and tires are ALL tube type.
The 22.5" Wheels and tires are tubeless and are the replacements for the 20" tube type.
All three of these wheels could have the 5/10 lug bolt pattern, but they may not have the same size center hole.
When looking for the comparable tires between 20 and 22.5, the 22.5 will be one size bigger than the 20. So your 9R 22.5 will match 8.25R 20 and a 10R 22.5 will match a 9R 20.
Hope this helps...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thank you all for clearing this up for me. Great info to know. Now i know what my options are. If i have any...
Thanks bolters!
You can get a radial 20" tire, but you still need the tube. The 20's are all lock ring...or whatever you want to call them.... because there is not the drop center needed for fitting the tire over the rim so you have to make the rim come apart to put the tires on. The 22.5 rims have the drop center. That's the easiest way to tell a 20 from a 22.5 from a distance or a picture.
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
Would you could you use a 20" split rim with tubed tires for highway speeds? Like 65-75 MPH?
8r-19.5 tires are 36" tall. that is trhe tallest 19.5 tire they make.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
That would be perfect!
Crusing in the Passing Lane
I think he said the bolt pattern is 'big 6 bolt,' There are lots of 22.5's w/ that pattern.
