10 members (chevy51truck, Gdads51, Phak1, 52Carl, KEVINSKI, Woodcmiami, Peggy M, Wickedbass, Tinker5, 1 invisible), 40 guests, and 1 robot.
Topics128,036
Posts1,055,458
Members48,422
#937443 04/21/2013 6:26 PM
Has anyone heard of putting an old Hemi in an Advanced Design, 1951, 3600 truck? I have a 1954, 331 Hemi and I would like to know if it will fit and clear the frame rails. If you know of it being done, how about letting me know!
Rick In VA #937445 04/21/2013 6:40 PM
do a search on the hamb for a guy who uses 65standard as a handle...his build is unbelievable......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Rick In VA #937449 04/21/2013 6:55 PM
You'll find that dimensionwise, the Hemi will have all of the same problems that putting a Smallblock Chevy in an AD has, only a bit worse, as the Hemi is much wider than the Chevy.
Bill Burmeister
Rick In VA #937503 04/21/2013 9:50 PM
I've seen an Olds 455 sitting between the rails of a '49. I've also seen plenty of LS motors in them too. Can't see any reason a Hemi cant' be done. I'm sure the inner fenders and steering shaft/gearbox will need to me massaged.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Rick In VA #937803 04/22/2013 10:45 PM
Thanks for your thoughts. The truck has a small block in it now and when you set the old hemi next to a small block it looks more massive. The heads are larger and I was concerned that there might not be enough room for headers to clear the frame without having to set the engine up much higher. I am not registered on hamb so I can't see 65standard's build but I take it he did put a Hemi in his truck. At any rate, thanks!
Rick In VA #937814 04/22/2013 11:31 PM
MNSmith #939763 04/30/2013 11:05 AM
Check out Hotrodsandhemis.com. Bill put a 331 hemi in his AD and gives a step by step pictorial for his project. He also has a lot of info on early Hemis.
Rick In VA #939857 04/30/2013 6:24 PM
Hi Gabbyp! Thanks for the site. I took a look and found it very interesting. I am going to email him and run some ideas by him. Thanks again. Rick
david dyehouse #940224 05/02/2013 2:32 AM
Ditto on that one Dave,I seem to remember he dimpled the inner fenders to clear the heads and headers.
Nothing's a problem for him though,he's a master with metalwork!
More pix on Flickr.
