0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | I'm looking at a 1993 Chevy truck heavy 1 ton. It has a 12' flatbed and it has 19.5 wheels 5/10 lug pattern. I want to put my 55 gmc 2 ton body on that chassis. My gmc currently has 9R 22.5 wheels. Big 6 lug. So my question/concern is I won't find any tall tires for the 19.5 wheels to equal or come close to my current tire height. (36" 37") So I'm wondering is the old dually 20" wheels that has the same lug patter.... I imagine I could bolt those old ones on the 1993 truck. So if I can.. Are there tubeless 20" 5/10 lug rims? If there are can you get tires for the 20" rim that can come close to 36" tall?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy beast54, there are no 5/10 bolt pattern 20" tubeless wheels that I'm aware of. After 1956 there were factory 22.5" tubeless wheels made for the whole truck line, but the 5/10 bolt pattern wheels were pretty narrow, and they seem to be extremely rare.
| | | | | Joined: Feb 2013 Posts: 111 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 111 | Good luck on that one. I am learning new stuff all the time here so it'll be interesting to read what others post here, but I think you are barking up the wrong tree.
As far as tires and their height for the 20 inch rims, even the 7.50 is usually a little more than 36 inches. Now, I'm talking "old truck" rims and tires here. Definitely tube type. Maybe the new custom styled 20 inchers would have a rim and (tubeless) tire that would work on the newer Chevy truck. I think some of them are quite large. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Beast54, Maybe I can help clear a few things up for you. The 19.5" wheels and tires are tubeless type. The 20" wheels and tires are ALL tube type. The 22.5" Wheels and tires are tubeless and are the replacements for the 20" tube type. All three of these wheels could have the 5/10 lug bolt pattern, but they may not have the same size center hole. When looking for the comparable tires between 20 and 22.5, the 22.5 will be one size bigger than the 20. So your 9R 22.5 will match 8.25R 20 and a 10R 22.5 will match a 9R 20. Hope this helps... Mike B  | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Thank you all for clearing this up for me. Great info to know. Now i know what my options are. If i have any... Thanks bolters! | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | You can get a radial 20" tire, but you still need the tube. The 20's are all lock ring...or whatever you want to call them.... because there is not the drop center needed for fitting the tire over the rim so you have to make the rim come apart to put the tires on. The 22.5 rims have the drop center. That's the easiest way to tell a 20 from a 22.5 from a distance or a picture.
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Would you could you use a 20" split rim with tubed tires for highway speeds? Like 65-75 MPH? | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | 8r-19.5 tires are 36" tall. that is trhe tallest 19.5 tire they make. | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | 8r-19.5 tires are 36" tall. that is trhe tallest 19.5 tire they make. That would be perfect! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I think he said the bolt pattern is 'big 6 bolt,' There are lots of 22.5's w/ that pattern.
