2 members (Svcattle, baldeagle),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93715 12/02/2005 3:05 PM | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | Just about have the wiring harness and all acc., etc. installed and hooked up on my 51 suburban, which is converted to 12vlt and went to double check that the voltage reducer was spliced into the right line for the horn relay and found that all my terminals at regulator, starter and intrument cluster were grounded to each other (ohm meter showed continuity between these components) Not good right? Is it back to the drawing board one terminal at a time to find the grounded one(s)? | | |
#93716 12/02/2005 6:32 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | sanderson,
This certainly isn't gospel, but my experience with this type of situation is.....it can be deceiving. If your circuits are fused properly, which they should be with a new harness, I would energize the system and see what happens.
Sometimes, you can get yourself "pre-confused" with checks of this nature. Good luck and be sure to report back on the results of your work.
Stuart | | |
#93717 12/02/2005 6:34 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A continuity check can not be done with the wires attached to the terminals. Of course there will be continuity from the starter to the regulator. That is the path the electricity takes. From the starter terminal to any other hot wire should have continuity. This does not mean they are "Grounded" to each other. It means there is a wire running between them. My guess is you have no problem. | | |
#93718 12/06/2005 6:51 PM | Joined: Nov 2005 Posts: 5 Junior Member | | Junior Member Joined: Nov 2005 Posts: 5 | Electric wipers are there any electric wipers that will mont in place of stock wipers on a 1951 3100. repacement ones are expensive | | |
