1 members (Gdads51), 159 guests, and 0 robots.
Topics128,188
Posts1,057,263
Members48,467
b10
Offline
My son inlaw just sent me a chrome valve cover that has a vented oilcap on it only.Will this cause a problem with air circulating to slow.The old cover has four slots for vents and a vented oil fill cap.I would like to use the new cover ,should i drill some holes in it to help give it more air or just leave it be. Feed back please. THANKS
It should work just fine. Your old cover likely has a newer cap on it instead of the twist on style that looks similar to a radiator cap and has no vents. Don't know offhand just what the 58's used but am pointing out the different types that have been used over the years so they get mixed up. I think the solid non vented ones were used on the draft tube engines with the slotted covers but I may be wrong.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
b10
Offline
Thank ,I did not want to drill any thing.This is not a part i would have picked up for myself.Going out right now to put it on . THANKS
1954 was the last year to use a vented valve cover originally, after that a vented cap was used. See pic #24 page #4 in this link
My Blog
b10
Offline
Looks just like the grey valve cover on you pic with a vented cap. 54-63. I just put the chrome cover on and it looks great.Pa would be busten my butt,to much Hollywood for him. Thanks.
There was no vented oil filler cap in 1954. As Dave posted, the valve cover was vented in 1954 (what about 1955-1st, Dave?).
You always have to remind me about the 55 1st don't you Tim.
Yes the 55 1st trucks I have seen used the 54 valve cover.
My Blog
