2 members (Gdads51, Guitplayer),
76
Mod | | | Forums66 Topics128,162 Posts1,056,950 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93679 12/01/2005 4:19 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | My Dad's Cousin Wally -- who is a State Trooper -- tells me that in order to be "Street Legal" in Michigan, I must have a horn. And by happy coincidence and possibly serendipity, My truck came with one.
There's only one caveat... the horn has to work. The horn that came with the truck does not.
My questions are:
-Can I use one of those big 6v flashlight batteries to test it? If not, How about a 6v battery charger? Yank it and hook it to the battery in the truck? (I have a 6v system in the truck)
-If it is indeed broken (and not miswired as I suspect), how do I go about repairing it?
I have exhaustivly searched the forums -- or, rather, tasked the search engine to do so for me -- and there don't seem to be any threads on the matter, nor are there any tech tips.
Any assistance anyone could provide would be greatly appreciated. | | |
#93680 12/01/2005 4:34 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | brendan, I have electrically confused half the forum this evening....it's your turn in the barrel. If it is a old truck with a conventional horn..no relay, then mashing the middle of the steering wheel grounds the horn. It is wired with a hot already. When you ground the horn, the little vibrator is suppose to do it's thing. You can run a wire from a good clean ground point, and touch it to a good clean point on the horn. Don't touch it to the other wire. The ground wire you touch should spark a little and if all is well, the horn will sound. At the very least, if is quiet, you should hear a funny sounding attempt to toot..sort of like a growl. You can coax it to toot, as you hold the ground wire on it, by tapping it with a screwdriver. It might have an adjuster/locknut assemble on the underneath which is used to fine tune the tone. Fussing with this usually silences it for good. Have fun! Stuart | | |
#93681 12/01/2005 3:52 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Brendan, at least you received a better response from Stuart then I did,,,, told me my issue was pointless  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#93682 12/01/2005 4:11 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Joker, I meant the distributor! Brendan, If your truck has the old fashioned horn with the long straight trumpet, it probably has a separate, insulated screw for ground. If you have a meter, make sure one post has 6v and the other post should be touched to a ground to toot the horn. Stuart | | |
#93683 12/01/2005 4:59 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Stuart:
According to the wiring diagram, there is a line going back to to horn button, and from there to ground. When looking at the horn itself, there are two screws on the top with wires coming out of them.
I'll give it a shot and let you know how it works.
Joker: [snicker] | | |
#93684 12/10/2005 10:49 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Okay, here's the deal. Someone at some point (my guess is when they put the Pontiac steering wheel in) rewired the horn. The horn is currently wired from the Fan (was the heater) to a button on the side of the steering column, to the horn. The horn is then grounded to the intake manifold. So, I fired the old girl up and touched a wire from the positive terminal to the batt terminal on the voltage regulator and I just about crapped my pants. Not only does the horn work, it REALLY works. So, in closing, I'll have to rewire it back to the way it's supposed to be. I'll probably have a peek at the rest of the wiring while I'm at it. Just because I know who used to own the truck. Thanks for all of your help! | | |
#93685 12/11/2005 4:33 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If you are going to keep that Pontiac steering wheel don't put the wiring back stock.
Get a horn relay (6 volt, might not be easy to find) and wire it to run the horn using the relay.
You'll be glad you did.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#93686 12/11/2005 5:44 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brendan, Too bad for the wash lady (da pantz  ) Your post said you touched a wire from the battery to the what? Maybe you do have a horn relay..it sort of looks like a voltage regulator. Toot Toot! Stuart | | |
#93687 12/11/2005 6:26 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Oldsub:
I haven't decided if I'm keeping the Pontiac Wheel or not.
I was thinking about putting in a relay, though.
atomarc:
Nope. I followed all of the wires. No relays whatsoever.
It's the voltage regulator. I looked at the wiring diagram before I started messing around, and the charging system looked like it was wired right, so I went for it.
And don't feel too bad for the wash lady. I am my wash lady, and I only "just about" messed myself. | | |
#93688 12/11/2005 5:20 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brendan,
OHHHHHHHH!!! Your post reads " from the positive terminal to the batt terminal on the voltage regulator"...that "positive" terminal was the terminal on the HORN...I get it, I hope.
Stuart | | |
#93689 12/11/2005 6:37 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | 'zactly.  | | |
