9 members (55shaker, 1955 1 Series, BC59, 3800GUY, RaNfLaS, tclederman, Otto Skorzeny, wilbur53, FAST55), 156 guests, and 0 robots.
Topics128,104
Posts1,056,201
Members48,436
#936625 04/18/2013 9:54 AM
Anyone know what would cause my hood (1953 GMC 3/4T) to hit the wipers when fully open? It actually hits the antenna first, but after removing that, it still rests against the wipers. Not sure if I need new hood hinges or if there is a way to adjust the stop point..
Thanks!
Here is the tech-tip for adjustment, I can tell you it is a two-man job for sure.
http://www.stovebolt.com/techtips/bodywork/ad_hood_alignment.html
Thanks, I will give it a look. As the hood sits correctly when closed, I assumed that there might be way to limit the opening while up. As if I move it forward to gain clearance, I think it might have an "overbite".. Anyway, thanks again.
