3 members (68ironhead, 49nut, 1 invisible), 49 guests, and 1 robot.
Topics128,049
Posts1,055,691
#936566 04/17/2013 10:20 PM
Ok I am cleaning up the wiring on my 1953 Chevy 3600 and here are my questions.
What gauge wire should I use from the coil to the distributor?
What gauge wire should I use from the coil to the ignition switch?
Thanks in advance.
1953 Chevy 3600
I stongly suggest you replace the wiring harness. They are not complicated and run about $150 (I think??)
If you are just making a repair, here's a wiring diagram with the wire gauge on it... Its for a 55, but should answer your question...
Hope this helps and welcome to the forum
wiring diagram
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
New wiring is a good upgrade for these trucks, after 60+ years it is usually pretty well shot. DMG is correct a new harness like this is what I bought.
http://www.classicparts.com/1950-52-Wiring-Harness-Generator/productinfo/52%2D023/#.UW93ycu9KSM
Makes a big difference when everything works reliably.
18ga. black
DG
Denny G
Sandwich, IL
Thanks for all the feedback
1953 Chevy 3600
So far so good. I bought a new battery today and popped it in and kicked it over a few times. Almost there
1953 Chevy 3600
