| | | Forums66 Topics128,048 Posts1,055,664 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | Ok I am cleaning up the wiring on my 1953 Chevy 3600 and here are my questions.
What gauge wire should I use from the coil to the distributor?
What gauge wire should I use from the coil to the ignition switch?
Thanks in advance.
1953 Chevy 3600
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I stongly suggest you replace the wiring harness. They are not complicated and run about $150 (I think??) If you are just making a repair, here's a wiring diagram with the wire gauge on it... Its for a 55, but should answer your question... Hope this helps and welcome to the forum wiring diagram
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | New wiring is a good upgrade for these trucks, after 60+ years it is usually pretty well shot. DMG is correct a new harness like this is what I bought. http://www.classicparts.com/1950-52-Wiring-Harness-Generator/productinfo/52%2D023/#.UW93ycu9KSM
Makes a big difference when everything works reliably.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | Thanks for all the feedback
1953 Chevy 3600
| | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | So far so good. I bought a new battery today and popped it in and kicked it over a few times. Almost there
1953 Chevy 3600
