0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
SO I have some slight orange peel on the hood and I am using SSU Metallic base. I know what caused it - I shot the paint when it was a bit too chilly.
Anyway it is not horrendous - but what are my options. I do plan on Clear coating it as well.
Hate to have to sand it all down and do again - but will do what I need to.
You CANNOT color sand the base coat as you will sand into the metallic flakes and ruin the look. Only option is spray several coats of clear to the point that "color" sanding will knock off the high spots of the clear coat only and leave heavy buildup of clear in the low spots. Might take multiple stages of sanding clear and re-apply more clear. Do NOT sand through the clear or you start over with base.
Might be easier to sand down the base coat and re-spray base.
Edit: Re-read your post, slight orange peal is normal and addressed by sanding clear coat.
That is what I will try - clearcoat 2-3 coats and then sand/buff
later on
