| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Over the winter i started taking my interior garnish off the '42. When I took off the wiper valence. I noticed the headliner had a sheet of tar paper on top of it?, Could this be factory?, For those who have'nt looked at my truck, it is a untouched original, But in 71 yrs who knows?. Has anyone else experienced or seen this? Thanks, Mike. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Yes it is factory, used to reduce the drum type sound effect you get in these trucks at normal speeds. You will find similar in the AD's, not sure if it is present in the TF trucks.
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | | | |
