8 members (Perro, Hush, Lightholder's Dad, John L., Otto Skorzeny, lumbersawyer, FAST55, Hanks custodian),
182
Mod | | | Forums66 Topics128,075 Posts1,056,007 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Using Dupont Urethane paint and want to also put on some clear. The tech sheet does not mention anything about when to apply clear - other than you can mix it with color.
If I apply within 24 hours of laying the base coat - I should not need to scuff up correct? | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | SO I did see this on the clear tech sheet. But I have a metallic base - a bit leary on sanding a metallic finish ----- If applying clearcoat to newly applied (but cured) paint, sand undercoat with 800 grit before recoating to ensure sufficient adhesion. ----- | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | I did a test panel with half sanded lightly to scuff with 800 grit and the other half not.
End result was no difference in looks after clear - so I will go with the light sanding with 800 grit before clear.
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | UhhG!! The DUpont Tech sheet never tells you how long you have to apply a recoat of the base.
Thought it looked great but after 2 hours (still tacky) I see a section that needs a bit more metallic | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | need to update the billing info on that Provider | | | | | Joined: Jun 2008 Posts: 48 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 48 | BSCowboy, I just checked the tech sheet for the chromabase basecoat and you have a 24 hour clearcoat maximum window. I would scuff and shoot another coat of base and follow up with the clear. | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | dupont tech just emailed me and said I have 24 hours to recoat. After that I should scuff with 600 grit prior to | | |
