5 members (Bill Hanlon, 52Carl, Otto Skorzeny, SmalltownTRKGuy, 1 invisible), 80 guests, and 3 robots.
Topics128,094
Posts1,056,058
Members48,433
#935592 04/14/2013 6:54 AM
Using Dupont Urethane paint and want to also put on some clear. The tech sheet does not mention anything about when to apply clear - other than you can mix it with color.
If I apply within 24 hours of laying the base coat - I should not need to scuff up correct?
SO I did see this on the clear tech sheet. But I have a metallic base - a bit leary on sanding a metallic finish
If applying clearcoat to newly applied (but cured) paint, sand undercoat with 800 grit before recoating to ensure sufficient adhesion.
I did a test panel with half sanded lightly to scuff with 800 grit and the other half not.
End result was no difference in looks after clear - so I will go with the light sanding with 800 grit before clear.
UhhG!! The DUpont Tech sheet never tells you how long you have to apply a recoat of the base.
Thought it looked great but after 2 hours (still tacky) I see a section that needs a bit more metallic
I cant find your server
Redryder pix
My Hotrod
need to update the billing info on that Provider
BSCowboy,
I just checked the tech sheet for the chromabase basecoat and you have a 24 hour clearcoat maximum window. I would scuff and shoot another coat of base and follow up with the clear.
dupont tech just emailed me and said I have 24 hours to recoat. After that I should scuff with 600 grit prior to
