4 members (tclederman, FAST55, JW51, 1 invisible),
88
Mod | | | Forums66 Topics128,269 Posts1,058,398 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | I'm interested in swapping my 3600 long bed cab & engine on to a 3100 short frame.
The only issue I foresee is moving from an open to a closed rear end, which is somewhere near 10" shorter....
It's a 4 speed floor shift, if that matters.
Thoughts and suggestions? Thanks.
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Get a 1/2 ton bed and you'll be in business. Your SM420 4 speed can be changed (rear bearing retainer) to run a closed or open drive shaft. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | Hey brother. So the long bed was open shaft? You could prob use that torque tube you had laying round or get one from Jeff. What engine are you using. If your using a gmc I think it will be to long for a chevy frame as the front mount crossmember on the gmc is further towards the front. I think you want a 49/53 frame as the 47/8 had lever shocks and 54 had a stepped bed or something . 54 beds won't fit a 53 frame and vise verse. If you remember the first gmc you had had a extension that was about a foot long. You just wouldn't have that extension. Does the short frame come with the t.t. And rear end? If so you should be able to just use that. But it uve got a gmc engine I'd try to find a gmc frame. If you can find a half ton long bed you won't need to worry About changing beds . Hit me up Dickson , sorry I've been crazy busy | | |
