Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Dakota Bob, dt235sd), 132 guests, and 4 robots.
Topics128,283
Posts1,058,505
Members48,490
i was looking forward to swapping out my 3.90:1 axle for the 3.38 set and i did it this weekend - a friend let me use the lift in his shop. i got an extra center section last fall so i could replace and set up the ring and pinion on the bench (and inside where its warm) over the winter. here it is:
new 3.38:1 rear
This made it a simple matter of swapping out one center section for the other:
empty housing
here's the new set installed
new gears installed
all back together
all back together
i changed the speedo gear in the transmission so my speedometer would read right, then took it for a spin. it drove well and i was turning about 2300 rpm at 55 mph. i am happy with it and i look forward to easier cruising this summer!
Nice work - looks like it was a fairly easy swap with a center section set up and ready. I like jobs that go like that!
How does it start out with the 3 speed? Lots of clutch slipping or not? Will be nice to hear how the milage is etc.
It starts out just fine. This is with an empty bed (no load), of course. My truck is a toy, and has 'retired' from hauling anything.. Starting off with a 1/2 ton load might be a different story, but for lazy cruising it is a great answer for lowering the hi-revs on the highway.
My first 59 gmc 1/2 ton shortbed had a 6 cylinder, 3 speed and 3.08 gears from the factory and 29 inch tires. No problem starting in 1st or second. Not so good at towing a trailor. Typically got 14-16 mpg with the original carb, and 12-14 mpg with a 4bbl holley. Truck weighed around 3500 lbs empty.
I had put the 3.38 gears in my current 59 gmc with pontiac v8 and overdrive transmission. The gears did ok with the 336 gmc engine, but the rearend did not survive the engine swap to a 59 pontiac 389 bored and stroked to 447 with 3 deuces. The rearend housing was torn apart.
I have since replaced the HO33 housing with a 9 inch, and changed the gears a couple of times. My gears now are lower than stock, but I still cruise 70 mph at 2500 rpm because of the OD. I may change the gears to around 4.10 for a little more economy. However the 4.30 gears I have now are real responsive with the 31 inch tall tires.
As far as mileage, here is how my 59 1/2 ton longbed did with various engine/tire,transmission combos. The truck weighs a touch over 4000 lbs empty, and with the spare gas and tools I carry, it tips the scale around 4400 lbs.
10 mpg with 336 v8 motor, 28 inch tires, 3.90 gears
12-13 mpg with 336 v8 motor, 28 inch tires, 3.38 gears with 27% OD transmission
13-14 mpg with new 447 inch pontiac motor, 28 inch tires, 3.70 gears, and OD transmission
14-15 mpg with 447 motor, 31 inch tires, 3.70 gears and OD transmission.
10-12 mpg with 447 motor, 31 inch tires, 4.30 gears and OD transmission
The transmission is a NV4500 5 speed adapted from a dodge 1 ton diesel pickup. There was a 4 speed sm420 in my truck when I purchase it.
The truck responded great with the 3.70 gears and the 28 inch tires. There was a noticeable loss of gearing when going to the 31 inch tires. Acceleration was poor in every gear. 4.11 gears with 31 inch tires should respond the same way as 3.70 gears with 28 inch tires. I ended up moving on to 4.30 gears for even better acceleration, however the loss in economy is killing me. I may switch to 4.0 to 4.11 gears for more economy.
With OD, you can have the low gears for acceleration, and still cruise at a respectable rpm.
The OD effectively gives you a highway rear end gearing. The NV4500 has a 0.73 5th gear for 27% OD
3.90 gears effectively become 2.85 gears in OD
3.70 gears effectively become 2.70 gears in OD
4.11 gears effectively become 3.0 gears in OD
4.30 gears effectively become 3.15 gears in OD
4.56 gears effectively become 3.33 gears in OD
5.14 gears effectively become 3.75 gears in OD
Anyway tire size, gears, and transmissions can be mixed and matched to give the desired performace. The OD transmissions give you the ability to have acceleration and economy. However you generally have to choose between the acceleration performance and the economy. You can have 1 or the other but not both. Some combos work better than others, but in the end, everything is a compromise.
This is a subject that I could use a little help on. I'm not stupid at math but for some reason I have trouble with gear ratios vs transmission vs tire size. My truck is a 47 1/2 ton will have the hot rod look just not the v8 go. I am using a 235. Wanted to go the Saganaw 4 speed with the 3.11 first gear and 3.55 rear end route. Trouble is I have a wide ratio muncie 2.54 first gear that I need to use. What rear ratio should I be looking for so I'm not slipping the clucth taking off and be able to cruse at 60? I have my eye on a 77 k-10 blazer with 3.42 rear gears. How do you think that 3.42s would work? I'm in the build stage so I have not made up my mind on tire size but I have some nice 15x7 rims I'd like to use. Thank you for any help.
Gears don't mean anything without tire size.
Best solution would be to use an OD transmission like the t5. There are other OD transmissions that will work like the 3 plus OD units used in the 50s and 60s.
The 235 has good torque. It should be able to pull 3.08 gears up to 3.90 gears and beyond. 3.08 gears with 29 inch tires will get you 60 mph @ 2070 rpm. This combo may not accelerate like a rocket ship from the stop lights, but it certainly will be drivable.
I am not endorsing the 3.08 gears, just confirming they will work.
Moderated
Moderated
new 3.38:1 rear
empty housing
new gears installed
all back together
all back together
I am doing the same swap starting this weekend. Where did you find the correct speedometer gear for the 318 tranny?
