2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
#93557 11/23/2005 4:37 AM
Can u guys show me how to correctly wire an alternator on my 1955 235. I currently have it connected but it does not charge the battery.
I looked on my amp meter and it has 2 poles, but they are not marked - or + ?
I have an aftermarket key switch.
Does it matter what type of alternator it is? The one on it was bought by the previous owner and I have no idea if it the correct on for the system. Thanks Jorge
1950 3100
1980 "Vette"
2005 Mustang GT
http://community.webshots.com/user/jlr1516
#93558 11/23/2005 1:01 PM
Take a look at madelectrical.com -- lots of info on this
#93559 11/23/2005 1:33 PM
I
I Offline
It would help to know what alternator you have. Is it a 10SI, 12SI.... 1 wire, three wire.... Internally regulated???
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#93560 11/24/2005 12:13 AM
Here's one link: http://www.oldengine.org/unfaq/10si.htm
And another: http://www.novaresource.org/alt/chargcircuit.gif
Still one more: http://www.rockcrusher4x4.com/images/pdf/DelcoAlternatorWiring.PDF#search=\'delco%20alternator%20wiring\'
Hope it helps.
#93561 11/24/2005 1:36 AM
Seon,
Those are excellent links. I farted around most of the morning peeking at alternator stuff and didn't find anything nearly as clear and concise as this.
Stuart
#93562 11/26/2005 3:31 AM
Awesome, Thanks guys!!
1950 3100
1980 "Vette"
2005 Mustang GT
#93563 11/28/2005 5:10 AM
Is this conversion relatively simple?
I am running 12 volts and a generator.
I thought this would be something I could do pretty easily..
