5 members (BC59, Danielbolt, Otto Skorzeny, Rusty Heaps, Peggy M), 104 guests, and 2 robots.
Topics128,093
Posts1,056,480
Members48,444
#935126 04/12/2013 12:46 PM
After about a year and a half of accumulating parts, I'm just about ready to tackle my truck project. It is a 1955.2 one ton with dual rear wheels. I would like to run 16" one piece wheels on the truck. I plan to swap out the rear end with a newer one with better gears, so no issues there. I tried newer (1973-up) dually wheels on the front. They fit and look good, but have less than 1/8" clearance with the tie rod end. I measured the distance fron the inside mounting flange to inside of wheel and it is about 7 7/8". The original 17" wheel is right at 7". So I measured every other dually wheel I have or could find at a recent swap meet, 16" GM and Ford, 16.5" GM, and even the newer 17" GM dually wheels. None is any less than the 7 7/8". Is anyone aware of a 16" wheel that is just a little more shallow than the standard dually wheel? I've been told I can use 19.5" bread truck wheels for greater clearance, but I would prefer to go with 16's to keep tire costs down. Any ideas or experience would be appreciated.
You can take the steering arms off the back of your spindle and shim it about 1/4 inch,it will give you about 3/8 clearance.You will have to realign the tie rod.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Moderated by  Dusty53
