7 members (Hotrod Lincoln, klhansen, Steelonsteel, Ribside, asilverblazer, greenie-reddy, 1 invisible),
63
Mod | | | Forums66 Topics128,261 Posts1,058,326 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 3 New Guy | | New Guy Joined: Sep 2011 Posts: 3 | After about a year and a half of accumulating parts, I'm just about ready to tackle my truck project. It is a 1955.2 one ton with dual rear wheels. I would like to run 16" one piece wheels on the truck. I plan to swap out the rear end with a newer one with better gears, so no issues there. I tried newer (1973-up) dually wheels on the front. They fit and look good, but have less than 1/8" clearance with the tie rod end. I measured the distance fron the inside mounting flange to inside of wheel and it is about 7 7/8". The original 17" wheel is right at 7". So I measured every other dually wheel I have or could find at a recent swap meet, 16" GM and Ford, 16.5" GM, and even the newer 17" GM dually wheels. None is any less than the 7 7/8". Is anyone aware of a 16" wheel that is just a little more shallow than the standard dually wheel? I've been told I can use 19.5" bread truck wheels for greater clearance, but I would prefer to go with 16's to keep tire costs down. Any ideas or experience would be appreciated. | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | You can take the steering arms off the back of your spindle and shim it about 1/4 inch,it will give you about 3/8 clearance.You will have to realign the tie rod.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
