3 members (stlcardinalsguy, dunfire, Otto Skorzeny), 110 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
#93506 11/19/2005 5:33 PM
Junior Member
Junior Member
I have a '50 Chevy Styleline deluxe. The car is 100% original with 46,000 miles. Anyway, the fuel gauge is not working properly. When I turn on the power for the car, the gauge moves from "Empty" to "Full" and stays there. What do you think is wrong with the guage? This is the only gauge that doesn't work.
#93507 11/19/2005 8:02 PM
It could be a few things. Since the car is 100% original, my money's on the sending unit. It sounds like it's either stuck or it's shot.
It is possible that the gauge has died a horrible, painful death, as well, but I'd check the sending unit first.
And welcome to the 'bolt! (Got any pictures?)
#93508 11/19/2005 9:39 PM
this may sound too simple, but ive had many gauges show only extremes one way or another, only to find out the wire to the gauge/sending unit wasnt making good a connection. easy to check at least smile
#93509 11/27/2005 5:25 AM
Junior Member
Junior Member
2 Offline
MY 69 3/4 TON'S FUEL GAUGE POINTS TO 3 O'CLOCK THIS COMES FROM AFTER SOME GAUGE REPLACEMENT TOOK PLACE.PROR TO THE GAUGE SWAP THE FUEL GAUGE WORKED FINE.WHAT IS WRONG?
#93510 11/28/2005 7:37 PM
Sounds like you have either the wrong gauge or a defective gauge. And please turn off the caps lock...
1954 GMC De Luxe COE
#93511 11/29/2005 4:24 AM
The gauge will go to "full" when the wire is not connected to the sender, may be broken or bad connection ?
You never have enough, til you have too many!
#93512 12/06/2005 2:05 AM
When your guage goes to full with power applied you either have a bad sending unit or a faulty ground. Make sure you replace the sending unit with a stock one or an aftermarket one with a 30 ohm resistance. Good luck.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
