7 members (TexasJim50, rick46ia, cmayna, Southerntruck, SNOYL, ShopRag, Mike Roache),
45
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,006 Posts1,055,271 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | whats your 235 engine temp while running down the road on a 80 deg day today i was running around and it was about 80 running down the road it was 190 and stopped it went up, i saw as highas 200,, is this normal ?
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | is this in the car? what are you judging that temp by? stock gauge, aftermarket gauge or ? .... have you checked your gauge against an actual thermometer measurement? if it's running an actual 180-190* I'd expect you have a 180* thermostat, which sets the minimum temp, might want to try a 160 for the summer - if the temp goes up a lot at an idle, you're not drawing enough air with the fan, if it goes up after you shut it off it's to be expected
Bill | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | below boiling should technically be fine, keeping in mind boiling point goes up with pressure. But, yes you need to verify the accuracy of your gauge vs thermostat rating. From 1984, up until last year I ran a 195 degree thermostat, that is what my dad always used, I don't know if it was gooder or worser, but the engine ran for 28 years that way. (with a few years off while I was terrorizing waikiki, I was bouncing at a GENTLEMENS club, AH what a way to spend your 20's) So in summation, the temperatures you present to us, are acceptable if accurate, but whether or not they are what you are supposed to have I don't know, I also don't know the condition of your cooling system, the proximity of your fan to the radiator, build up in your radiator, things like that. You should get one of those little laser gun therometers, (what am I saying, I need to get one of those little laser gun thermometers) | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | it is car ,, i had the motor rebuild last fall and had the rad cleaned and flushed , they told me it was 80% dont know what that means ,, the fan is about a 1" from the rad .. were is a good place to check with a laser gun ?? all i can go by is a gauge that i mounted inside ,, what about rad cap??? i was told that to use a flip top style and to use a 12 lb ,, he said that the regular style dont seal as good good ,, so that being said what lb should i run ??
thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I wouldn't use more than 7# on an original 58 rad, which I think is what the manual would call for, and the flip top type just gives you a safety when removing the cap hot, they don't 'seal better' - you shouldn't even need to have the cap on tight for it to stay at the proper temp if the cooling system is all good - also do not overfill the rad, it should be down at least an inch or it will push out the excess, or with too high a rated cap, will crack a seam in an old rad
with the laser, check the thermostat housing for the "high temp" and check the lower rad hose or it's input at the water pump to see how much the rad is cooling, should be at least 10-15* difference - check the rad top and bottom tanks too - the stat housing temp [when warmed up] should be close to the stat rating, and stats can go bad or be defective out of the box .... can also check around the block to see if there's a hot spot that might indicate a plugged passage
Bill | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | good stuff there red58 what did you mean (I wouldn't use more than 7# on an original 58 rad),, is that 7 lb cap ?? ,,,, my fluid is about a 1" down and i think i am runnig 50 /50 and i used distilled water too not tap water ( dont know if that makes a difference ) but i will check with laser gauge
thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, for the trucks anyway, the original was a 7# cap, the era cars should be the same, a higher pressure will just stress the rad for no gain, they weren't designed for it
Bill | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | thanks red58
i will look tomm for a 7 lb cap ,, i think i am running a a 12 lb now ,,, hey what you think about oil ,, had a guys tell me that he runs 20w 50 in his cars ,, hes got a 58 yeoman and a 59 el camino , i run 30 now and i am due for a change after my rebuild ,, and should i add some zddp ???
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the zinc is only useful on a fresh rebuild, if you've been using regular oil all along, no need to change that - I use 10-30 for my old bolts, 20-50 is usually for diesels and for me is overkill unless summer temps are real high and your using it hard, I might use it in a high mileage small block and likely will in the 454 going in my vintage RV
Bill | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | I put 30w in right after the rebuild and i am ready for a oil change, i though it might help because iam running a little hotter than normal thats all ,, am i understanding it right that 20w 50 starts off like 20 and as it get hot it goes to 50 ? Thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | about multi grade oil, it's vaguely as you say .... I didn't catch that you'd just rebuilt it, folks do usually use the ZDDP additive or diesel grades with zinc for the first while, but I don't think not using it would contribute to temperature, and I'm not convinced it'd be a real wear problem not using it .... hopefully your rebuild included good assembly lube Bill | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I wanna know just who you were bouncing (on) at that Gent's club...rowdy customers or hot dancers ..;)
Noe back to you're regularly scheduled programming... | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | Yes it was assembled right, ,i am thinking i have rad troubles on the running hot, ,not rwal ot just 200 at idle, ,
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | D. All of the above. I can sure spend some time looking back on all that......
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | now back to the matter at hand, 20-50 would be most likely to heavy. There are at least 2 very good articles on oils, with emphasis on zddp levels. One is by Bob Olree, a GM, or at least retired GM engineer, who by several accounts is virtually without peer in this field, and one I just found the other day on VCCA a fella named Vidman. Who is, or was an engineer in this sort of stuff for several of the major oil comapanies. They both say pretty much the same thing, but given the probable oil temp achieved in these engines 20-50 would be way out of its acceptable range. (this is one of the reasons I want to get one of those little laser gun thermometers.) I won't try to summarize their articles, because, well, they already did it. The one interesting thing I found out is, the zinc (the "Z" in zddp is there for anti-corrosion) While it is actually the phosphate, (maybe phosphorus, thats why I let them tell the story) the "P" in zddp is the actual anti scuffing ingredient we are looking for. The article by vidman is very recent and includes the little code numbers and what not to look for on the side of oil containers, mostly it seems the diesel oils are the ones with the appropriate amount of zddp, but here again, you read the stories and make your own decision. As far as your overheating, technically if it is below boiling and it stops rising, it isn't overheated. Did you use a new/different thermostat upon reassembly? As I said I ran my truck at 195 (why is there no symbol for degrees on these computters?) for 28 years, as well as every car I owned up until recently when I started buying new cars, and I have a feeling the new cars run even hotter, but I don't know that for sure. I have never had a fresh engine get hot, I have only built 2 auto engines, as I have never really had one fail. But diesels we would rebuild at least one a year for the about 20 years I spent up in alaska and in the merchant marines. So as long as it stops by 200 degrees, you are fine. Nonetheless, you should double check the accuracy of your gauge, which since you never mentioned water blowing out the top of the radiator like a geyser, seems to be accurate enough. The most important part being is the water stays in the engine, once it starts blowing then you are screwed.
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Get yourself a digital inferred meter. They run about $35 and are a good tool to have. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | As others have mentioned 200 is not a problem, especially using a 7# radiator cap. Also confirm the actual temperature using a heat gun. I've always used a lighter oil for the initial break in on a fresh motor. With a stock motor 5-30 or 10-30 is fine. You can actually do more damage with to thick of oil than to thin. The only time that oil can play into water temperature is if the oil temperature is rising higher than normal, then it can raise water temperature. I drive truck for a living, I find that the engine oil temperature can rise some if I have a heavy load and I'm really working the engine, especially on a long and or steep hill. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | ok so what i am getting is stay away from 20w50 and stay witha 30w or a 10w 30 ,, what do you guys think about Synthetic oil ,, here in our shop were i work we use 15w40 full synthetic real green , i would love to use this oil i could change every 2k or less ,, but i have read to stay away from them ,, thanks for the info i will get me a heat gauge do some real test , i am going to take the rad out and get it look at by another shop and see what they say ,, i would like to look into making some kind of fan shroud that would help pull more air across the rad away thanks again
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | Ok i got a lazer for temp wheres the best place to check it? top of state houseing?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check all over the place  .... with the laser, check the thermostat housing for the "high temp" and check the lower rad hose or it's input at the water pump to see how much the rad is cooling, should be at least 10-15* difference - check the rad top and bottom tanks too - the stat housing temp [when warmed up] should be close to the stat rating, and stats can go bad or be defective out of the box .... can also check around the block to see if there's a hot spot that might indicate a plugged passage
Bill | | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | Hi all, I would agree with all who suggest using a laser thermometer,I have an international harvester grain truck that always shoes above normal water temp, tried changing sender,go to I.h. Buy replacement dash gauge,found cracked rad and repaired,changed thermostat,etc,no change in temp reading,borrowed friends laser gauge and low and behold engine running 20 degrees cooler than gauge reads. Always remembered that head is usually always hotter than rest of engine but also checked various areas of head, block,even water pump. Will get laser temp gauge when I get a chance. Pat
1966 Chevy C 30 1 ton truck
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | on the temp part here what i have car at idle for 30 min in drive way gauge is 200 bottom stat-176 top rad -170 bottom rad hose-159 top rad hose- 169 intake carb side -187 top of head- 209 top of head at gauge port-190 bottom block 200 side head at spark plugs 203 water pump heater hose 182 exhaust 356
