8 members (sron48, Uncles51, gswbbc, Hanks custodian, FAST55, 32Fordpuchoptop, Joe W, 1 invisible), 149 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#934900 04/11/2013 4:15 PM
1949 Beast
1949 Beast
Can anyone tell me if I can go to a 15 inch wheel / 8 bolt on my 49 Chevy 3600?
#934917 04/11/2013 5:24 PM
Sure, why not? Are the bolt holes correct, and is the off-set correct?
#934935 04/11/2013 6:26 PM
I think you will have better luck looking for 16" wheels. Lots of choices there, easy fit possible on the back axle, front is a different story. backspace on most modern wheels will not clear the tie-rod ends. Research the topic here, you will find numerous posts if you search on this topic.
Brad Allen #939585 04/29/2013 8:14 PM
1949 Beast
1949 Beast
any idea which 16 inch newer style will work? I am trying to get black stock like wheels and put on 16 inch tubeless tires
#939590 04/29/2013 8:42 PM
My wheels are off a 1991 3/4-ton Suburban so any similar year 8-lug Chevy wheel should fit. I also think people have posted that 8-lug Ford and Dodge wheels will fit as well. I don't know on those personally.
#939647 04/29/2013 11:19 PM
The later model Chevy rims may not work. They have too much offset, same goes for the Dodge. They would be o.k. on back, but on front they'd hit the tie rod. Your best bet is from Ford E250/E350.
Dexstar Trailer wheels are a good option also.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
