| | | Forums66 Topics128,041 Posts1,055,593 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 23 New Guy | | New Guy Joined: May 2009 Posts: 23 | Is there a configuration of SBC that can be installed with an automatic transmission in a 1952 AD that does not require changing the original steering system. This has probably been answered before but I can't locate it and need to get my plans in order. | | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | Usually the exhaust manifold on the drivers side is in conflict with the original steering box . Some chevy manifolds go up along the valve cover instead of down right away (if that makes sense) and these help on clearance , Also I have seen something about moving the steering box outward - away from the engine alittle bit. Most likely the engine/trans. will have to be offset towards the passinger side a bit instead of being centered exactly in the frame. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I think they refer to those manifolds as "Ram's Horns"...
fairly inexpensive and in reproduction in a couple of places
| | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | I have ramhorn manifolds on my truck now {with the rack and pinion ) but on another truck I built (with stock steering box) I used 1955-1956 265 manifolds . They go up from the exhaust ports (like the ramhorns) but the "dump" was between the 1st and 3rd exhaust ports - which cleared the steering box . I think there was a similar manifold used on some '80's chevy cars also. | | |
