3 members (wilbur53, MickeyP, dt235sd), 59 guests, and 0 robots.
Topics128,049
Posts1,055,552
Members48,425
#93461 11/16/2005 2:19 AM
Junior Member
Junior Member
Does anyone know if I can keep the 6volt guages when I convert the truck to 12volt V-8 . I really want that original look on the interior.
#93462 11/16/2005 2:43 AM
what year.?? older ones the oil pressure is manual and should be ok.... the amp gauge is ok (amps is amps,,and amps dont care bout no volts hehehe)... and for fuel gauge you can get a resistor for it..temp gauge is probably manual too...??? if not maybe can get new sender or a resistor also...dont forget the heater fan also.....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#93463 11/16/2005 5:15 AM
Fatweed is right but let me reiterate - DO NOT FORGET THE RESISTOR FOR THE FUEL GAUGE. Running 12 volts thru it will burn it out in a second. I know!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#93464 11/16/2005 3:03 PM
Junior Member
Junior Member
Thanks guys! I have a 50 gmc that am rodding out. S-10 frame, SBC 307 ,Air ride suspension. This is all happening over the course of a couple of years.
#93465 11/16/2005 5:56 PM
I think some of the parts houses offer gauge clusters rebuilt to run on 12v.
1954 GMC De Luxe COE
#93466 11/16/2005 6:44 PM
Junior Member
Junior Member
My 54 100 has mechanical temp and oil pressure gauge but 6 volt fuel gauge ..it's blown..I need a 12 volt 54 fuel gauge ..anybody sell them?
#93467 11/16/2005 9:28 PM
BS,
American Classic Truck Parts sponsors this site and they have the 12v 1954 Fuel Gauge listed in their catalog.
Tim
#93468 11/16/2005 10:59 PM
Tim...BS! grin grin grin Your sense of humor is hanging out Dr.L.
Stuart
#93469 11/16/2005 11:51 PM
I believe Bowtie Bits can covert your stock gauges to 12V. Might contact them to check on cost. Cecil............
#93470 11/17/2005 10:09 PM
Junior Member
Junior Member
Thanks Tim..i found it..
Roger
#93471 11/18/2005 12:26 AM
Someone once calculated the power consumption of the gas gauge on 6V and 12V and they were both insignificant. I haven't taken the time to measure it but we ran the '48 truck on 12V for years with no problems with either the gas guage or the electric temp gauge. Just something to ponder...
Jason
#93472 11/18/2005 2:39 AM
A '55-'59 GMC 12V fuel guage will fit in your '54 GMC dash.
#93473 11/18/2005 9:35 PM
Junior Member
Junior Member
I'm trying to install a throttle cable in the 54 gmc..It seems the tension on the accelerator return spring is going to overwhelm what ever force the throttle friction cable has so the throttle won't work.
Am I overlooking something obvious?
Roger
#93474 11/19/2005 1:50 AM
Bat Guano, this should be a separate post to make it easier to find later, but....
The original cables would lock in place if you twist it. I've read the replacements don't.
#93475 11/19/2005 3:36 PM
Junior Member
Junior Member
Thanks Cletis..this had been such a helpful smart group, I thought I'd keep it here.. The original ones must have either locked or used a special carburetor which I haven't seen
#93476 11/20/2005 5:11 PM
The only gauge you need to worry about is the fuel. You can use a stock 6v gauge and just install a runtz resistor between the 12v wire and the gauge. Randy and 5th ave can sell you one. I've had this set up for a couple three years now and the gauge works just fine.
I also remember installing a resistor in front of the heater switch so I wouldn't burn up the heater motor.
Craig
#93477 11/21/2005 1:07 AM
Junior Member
Junior Member
Thanks..I'll try a runtz as soon as I find my old gauge is OK
