1 members (klhansen),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | Question. What was the floor mat for the Suburban? Was it the same as the truck or did it have a section under the jump seat? Also, does anyone have a picture of the floor pan section under the jump seat area that they could send me or direct me to? Some P.O. has put a panel over the original floor in that area, or at least it looks that way, I'm not really sure what it is supposed to look like. Thanks, Coffeeman | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The front mat from the pickup fits my '54. The remains of a ribbed mat was under the jump seat when I got it. I have not been able to determine if it was original. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The floor panel you are talking about could be original. They welded in a plate to cover the indentation of the floor so they could mount the flip seat and brackets. . The floor pan is the same used in the pickup trucks with some modifications to fit the rear flooring. The matting used was similar to what Cletis posted, but I can't tell by his picture that it's original or not, I believe that the suburban and truck models used black material and his looks like it's faded brown. | | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | Ahh, G, that makes sense as it is spot welded in. It just isn't cut very well like you would expect a factory plate to be. I will be finished cleaning it up hopefully today and post a better pic of it. Any idea where to get the matting that goes in that area? Thanks- Mitch | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | Yep, that's exactly what mine looks like. Thanks for the help! | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | You will notice that there are two raised pins at the rear of the seat area close to the rear floor. These are for attaching the mat so it will not move around. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I think my under seat mat was black to start with even though it doesn't look like it in the picture. | | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | After scraping and grinding, I have uncovered the ugly truth. the spot where the back bar of the seat rests on the floor is ripped. I think what I am going to do is dolly it back into shape, weld it shut and then cut a piece of 20 ga. to fit between the factory piece and the rear floor step-up. It wont be original, but I'm not really going for the 100 point restoration. The factory piece looks unfinished anyway so this should make it look better, IMO. | | |
