2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Junior Member
Junior Member
I have a 48 Chevy Loadmaster 1 1/2 that has no brake lights. I purchased a new brake switch and installed it, but no power is getting to the switch.
I have looked it over and found a fuze link under the dash but the end has been cut off. Is there a hot wire that comes off the fuze box that runs to one side of the switch?
I would like to know where to start on this problem.
Thanks for any help!
You thought I drove a Ford! Where is my cresent wrench, I would like to adjust your thought pattern.
I
I Offline
This will take you to my wiring diagram.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001679#000000
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
Riding in the Passing Lane
There should be a hot wire going to the stop light switch hot all the time. The other term. goes to the turn switch if equipt with 7 wire turn switch. If not it goes to the stop lights.
1972 Chevy c10 Cheyenne Super
