2 members (moparguy, 51sub), 103 guests, and 4 robots.
Topics128,070
Posts1,055,892
Members48,428
I changed the gear oil in the my 4 speed transmission. The book says 2 1/2 pints. I have put in 2 quarts and it still isnt full. I changed it on a flat drive way no jack stands. IS that a miss print
Also, I have questions concerning the gearing.
1st is slow low, I don't even use it.
2nd seems to be very short. In that I soon shift out to 3rd. Is that right?
3rd and 4th seem to be lacking power. I think this might be a gas problem. But I am not sure.
Any thought or suggestions?
Lost
1952 Chevy 3/4 ton
1948 Simplex Motorcycle
1930 Ford Model A Coupe
1928 Ford Model A Station Wagon
According to both the shop manual and owners manual, the 4 speed capacity is 6 pints.
The ratios on that trans are; 1st gear-7.06:1, 2nd- 3.58:1, 3rd- 1.71:1, 4th- 1:1, Reverse- 6.78:1. Couple that with the 4.56:1 ratio in the differential, it makes the first virtually unusable for anything other than getting a load moving, and second isn't much better.
On the lack of power issue, before you go digging in the feul system, you may consider checking the timing.
Bill Burmeister
Lost,
Is this your 1952 Chevrolet 3/4 ton truck?
Which book said 1.5 pints gear oil in transmission?
My oops I read it in the Chevy Truck Shop Manual but it for the 3 speed. Truck Manual.
I found the correct page truck manual
1952 Chevy 3/4 ton
