7 members (55shaker, Bill Hanlon, Jon G, 78buckshot, TrknGMC, Joe H, 1 invisible),
99
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 19 New Guy | | New Guy Joined: Dec 2012 Posts: 19 | I changed the gear oil in the my 4 speed transmission. The book says 2 1/2 pints. I have put in 2 quarts and it still isnt full. I changed it on a flat drive way no jack stands. IS that a miss print
Also, I have questions concerning the gearing.
1st is slow low, I don't even use it. 2nd seems to be very short. In that I soon shift out to 3rd. Is that right?
3rd and 4th seem to be lacking power. I think this might be a gas problem. But I am not sure.
Any thought or suggestions?
Lost
1952 Chevy 3/4 ton 1948 Simplex Motorcycle 1930 Ford Model A Coupe 1928 Ford Model A Station Wagon
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | According to both the shop manual and owners manual, the 4 speed capacity is 6 pints. The ratios on that trans are; 1st gear-7.06:1, 2nd- 3.58:1, 3rd- 1.71:1, 4th- 1:1, Reverse- 6.78:1. Couple that with the 4.56:1 ratio in the differential, it makes the first virtually unusable for anything other than getting a load moving, and second isn't much better. On the lack of power issue, before you go digging in the feul system, you may consider checking the timing.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Lost,
Is this your 1952 Chevrolet 3/4 ton truck?
Which book said 1.5 pints gear oil in transmission?
| | | | | Joined: Dec 2012 Posts: 19 New Guy | | New Guy Joined: Dec 2012 Posts: 19 | My oops I read it in the Chevy Truck Shop Manual but it for the 3 speed. Truck Manual. I found the correct page truck manual
