| | | Forums66 Topics128,154 Posts1,056,855 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93408 11/08/2005 3:54 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | hello,
i just recieved my new turn signal mechanism from lmc. i am wondering if anyone can tell me how the heck it goes together. there is the main piece, which is easy enough. but then there is this little arced spring that i am not sure what to do with, there are two little brass loops that must connect to it somehow. i know that it attatches to the mechanism somehow, but how? my old one was completely broken when i removed the whell, so no help there. a diagram, picture, or description would be most helpful. also i am not sure how the cancelling cam goes back on there as that there was not one in there when i opened it up. please help, my sanity hangs by a thread. thanks in advance, the green hornet thanks you as well.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
#93409 11/24/2005 6:53 PM | Joined: Aug 2005 Posts: 39 New Guy | | New Guy Joined: Aug 2005 Posts: 39 | Hi,
I only noticed your post now. I just got a turn signal switch from the wrecker the other day. It came out of a GMC truck and my guess is that it was from the early 60s (only the chassis and the cab were still there). Anyway, if you're still struggling I can take a picture of what I have, if you think that will help.
Johannes
Simplicity leads to reliability.
#93410 11/26/2005 1:03 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | johannes - thanks for the reply, does your mechanism by chance have the "cancelling cam" in it, i ordered one but i cannot figure out how to put it on. i got everything else put back together and it all works, but it would be cool if the cancelling cam worked. thanks for the reply.
#93411 11/26/2005 5:21 PM | Joined: Aug 2005 Posts: 39 New Guy | | New Guy Joined: Aug 2005 Posts: 39 | Fort Knox,
Sorry, no cancelling cam, nor did I pay any attention to what it looks like and where it goes. I'm using the switch for a 52 GMC which originally had no turn signals. I don't like those clamp-on retrofit switches, and I figured that this one would be relatively easy to install on my steering column. I will not have auto-cancelling though.
Johannes
#93412 11/28/2005 9:32 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | there should be a couple of threaded holes on the back of the steering wheel that the cancelling cam attaches with.Not sure what thread pitch or size,probably 10-24 or something like that.Good luck! Speed | | |
