1 members (1955 1 Series),
131
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | That rear piece is the old race. It needs to come off. They usually pull right off by hand but you should be able to pry off.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | If the old bearing failed, it may be pretty tight. Try prying first, but if that doesn't work you may have to heat the race to expanded it. If the bearing got real hot, I have had to go so far as torch races off. Hopefully, yours isn't that bad. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Say there AZ, are there any numbers or names on those tapered bearings? I'm sure some of us would like to see them or have you post them here.
Thanks Denny G
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | Denny, those bearings aren't a BCA number. I bought some several years ago. They are made in China and have numbers that don't cross over to any thing. I decided to put in used ball bearings after closely examining the tapered bearings. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the "good" rollers are actually MBS, a Japanese brand [ here if you speak the lingo], and from previous threads here on the bearings, the dimensions are not an exact match for the ball style .... for Denny: Inner: MBS 909052R, Outer: MBS 909001R [or MBS 909067R] Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Bill, put that in the data base. Won't fit my 3600's for sure but if I run into a 1/2 ton road runner that someone wants rollers in I'll have the numbers. What exactly so ya mean, "dimensions are not an exact match?" How could they be used if they don't fit? Is there some sort of modification that needs to be accomplished before you can install them? I mean ID & OD have to be the same unless you have the capability to turn the spindle and hub. It wouldn't surprise me if the thickness of a roller was more than a caged ball but there is usually enough thread on the spindle to adjust for that as long as you can still get a pin thru the nut. Just looking thru my reference material and those are the same numbers the Charlie posted once before, Thanks guys, got them both in the data base now. Denny G Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | outer: MBS 909001R: bore=19.057mm/ diameter= 52.832mm/ Ball Bearing [B01]: Bore=19.044mm/ Diameter= 52.8447mm
Inner: MBS 909052R: bore:32.550mm/ diameter=72.260mm/ Ball Bearing [B40]: Bore=31.760mm/ Diameter=65.1256mm/
| | | | | Joined: Jun 2012 Posts: 13 New Guy | | New Guy Joined: Jun 2012 Posts: 13 | Thanks again guys for all your help. I don't know what i would do without all of your help! Well actually I do I would cuss and fight things a whole lot more and not make any progress. I will give it a shot the races spin but don't slide off I will try heating up and see what happens. | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | What I see in the photo is since the spindle has that large fillet radius, it is likely the bearing race does not have the clearance for it. Actually the bearing looks too small. And I didn't see any old race there? Don't know what the first poster was talking about.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | And I didn't see any old race there? Don't know what the first poster was talking about. Looks like the old race to me. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Lets see if I got this right Bill. outer: MBS 909001R:………Bore=19.057mm/ Diameter= 52.8320mm Ball Bearing [B01]: Bore=19.044mm/ Diameter= 52.8447mm I can see how this would work, the roller ID is only .0005” bigger and the OD is only .0005” smaller. But I would still use a drop or two of Locktite bearing mount just to be safe.
Inner: MBS 909052R:………Bore=32.550mm/ Diameter=72.2600mm Ball Bearing [B40]: Bore=31.760mm/ Diameter=65.1256mm The ID according to those dimensions is a full 1/32” bigger than the stock ball bearing, even the bearing mount won’t make up for that much clearance so that would be a pretty sloppy fit even with help. Now the OD, if your numbers are correct, is .282” bigger than the ball and there is now way that would fit unless the hub was bored out. Don’t think I would like to mess with that one unless of course the numbers are off by a bunch.
Denny Graham Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | when the roller thing was hashed out some time back, that's the dimensions I noted, from searching the net and talking to my NAPA they are not identical replacement for the ball bearings, but if you add 'R' to the ball numbers [to indicate rollers] you may find someone with some NOS around, they were made at one time other discussions about the rollers: the HAMB .... Classic Parts forum .... the 67-72 forumand for the record: a PDF catalog listing ball/roller interchange and applications .... a Chinese supplier with dimensions .... an e-bay seller .... a rod shop supplier that appears to source them from CPP, who may be distributing the Chinese version .... I ran across a note somewhere that the reason MBS bearings aren't common is they got fined for a "dumping" trade violation some years ago Bill | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | I have no clue what a "large fillet radius is, but what I see is the the inner bearing cone and the oil deflector. | | |
