2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Is there much customizing required to get 54 check arms to fit on 58 Panel barn doors? A fellow bolter has a set, and I am sure they are hard to come by.
Thanks all. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | they have some obvious differences, but are quite similar - I only have pics of the AD ones so don't know if the dimensions [particularly of the mounting holes] are close enough to work - it's likely they can be made to do the job, but if you can get lengths of both arms on one as well as the hole spacing I could compare to the TF ones I have here
Bill | | | | | Joined: Apr 2013 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 101 | Thanks Bill, I will ask the seller. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | easier maybe, I got the measurements, have him check his AD ones against this, mount at top right goes on jamb above door [arm has a bend not obvious in the pic but bumper is up off table], mount on left attaches to top of door where there are already threaded holes [I think AD arms don't have the 'ear' on the end] Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Ok, I'll ask the stupid question... What are "check arms?" Are they what keeps the barn doors from flying around and smashing against the body when the doors are opened??
Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes Larry, like this, mount at top of doors, they hold the doors straight out or allow them to open wide enough to point out to the sides Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Bill;
Roger. At least that is one thing I don't have to worry about finding. Now if I could just get a set of liftgate cables for my clamshell I'd be all set!
Larry
Larry
| | | | | Joined: May 2013 Posts: 5 New Guy | | New Guy Joined: May 2013 Posts: 5 | Ted, I have a '53 panel; if you don't buy the '54 arms, would you please give me the seller's info. Thanks, Larry [email protected] | | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | were you ever able to get an answer or try this out? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Ted, G is right you can make anything work but if you have patience and wait, you will find the right ones with an ad in wanted and watch the internet. That would be much better. It's always nice to have the right part. They are still out there. They still make the rubber bumpers for them also. If you are not picky, the proper sized gas springs will work nicely. O'reilly's, etc. Mounted at top.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | Please use email and/and Private Messaging for personal sales. | | |
