2 members (lumbersawyer, 78buckshot), 167 guests, and 3 robots.
Topics128,142
Posts1,056,474
Members48,441
#93375 11/04/2005 11:08 PM
kam
Offline
Junior Member
Junior Member
KEY WONT START, CRANK MY TRUCK. I HAVE 12 V TO THE IGNITION SWITCH BUT ONLY HAVE 4.5 V TO THE STARER SOLENOID WHEN I TURN THE KEY TO START. ANY IDEAS?
#93376 11/04/2005 11:19 PM
kam,
My first thought would be a bad battery.
Stuart
#93377 11/04/2005 11:47 PM
Riding in the Passing Lane
Try jumping from the s term. on the selinoid to the bat. cable term. If it works then the problem is in the switch or connections. Stuart is probably right.
1972 Chevy c10 Cheyenne Super
#93378 11/08/2005 5:40 AM
maybe bad wires
50 chevy 3100
#93379 11/15/2005 4:55 AM
Junior Member
Junior Member
a high resistance in a connection, check any connectors and the bat posts for corrosion
dare to be different, fear being the same
1952 gmc 1/2 ton
1998 chevy 1/2 ton
