6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
#933143 04/05/2013 11:24 AM
Changing the generator to alt. on my 55.2 TF truck. What did you guys do for a pulley on the alt., so you can still run the wide belt that fits the crank and water pump pulleys.
TIA.
Brian
Brian
1955.2 3100 Truck
you need to find a wider [small] pulley for the alt or find narrower ones to replace the other - a 'happy medium' will work as long as the belt doesn't bottom in the groove or protrude much
So where would a guy go look for this smaller wider alt. pulley?
Brian
Brian
1955.2 3100 Truck
Or, you can do what I am doing: I purchased a dual 3/8" grove harmonic balancer from Buffalo Enterprises (A nice piece that took over two months to receive). I used a '53 water pump for my '52 216 (has the 3/8" grove pulley). Now I am setup for modern 3/8" belt size and have an extra grove on the balancer for future needs. And, I can use a standard alternator.
first stop for me would be a local auto electric shop
Jim Carter has them,I put one on my 52 5 years ago.Also you'll need a in line diode on the exsiter wire from you're key switch to the alt. if you install a 2 wire alt.so the power only flows from you're switch to the alt. and not back to the switch after you turn the truck off .You can get one from a radio shack or jim carter has them to.
Pete
Use the pulley from the generator on the alternator. A bit smaller diameter pulley would be better but the one from the generator will work fine until you find something better.
Want to sell the generator? I'm looking to switch from a 6 to 12 volt one.
It's already been sold.
Brian
1955.2 3100 Truck
I believe a good automotive electric shop can re-wind a 6 volt generator for 12 volts.
