3 members (homer52, Bill Hanlon, 1 invisible),
140
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | First, I apologize if I'm asking a repeatedly asked question, but I can't seem to find here (or elsewhere) what the best model or models of Carter 1 bbl carbs would be best suited to replace my 2nd leaky Rochester on my '62 Chevy C-10 with a 235.
Can anyone help me?
Thanks!!
Glen | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Best one would be a 2100S for a Chevy app.
Pete | | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | Thanks Pete! Is this a manual choke model? (Now to just find one!  ) | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | This has hit home for me. I have rebuilt three Rochester B cores and all three leak like a banchee, Carb King has put out the warnings on them. I have a couple questions on the Carter, will the choke and throttle cables work wih them and does the factory air cleaner work with it. I'm talking about the 2-15/16" model size 3 for my 56 model 235. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Yes, Air cleaner and cables will fit
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | I found a YF 2101S, it says fits 235. Any idea what the difference is? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | Ah. Good to know. That's not the one I want  | | |
