3 members (Deegs53, tclederman, 1 invisible),
268
Mod | | | Forums66 Topics128,078 Posts1,056,054 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Changing the generator to alt. on my 55.2 TF truck. What did you guys do for a pulley on the alt., so you can still run the wide belt that fits the crank and water pump pulleys.
TIA.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you need to find a wider [small] pulley for the alt or find narrower ones to replace the other - a 'happy medium' will work as long as the belt doesn't bottom in the groove or protrude much
Bill | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | So where would a guy go look for this smaller wider alt. pulley?
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Or, you can do what I am doing: I purchased a dual 3/8" grove harmonic balancer from Buffalo Enterprises (A nice piece that took over two months to receive). I used a '53 water pump for my '52 216 (has the 3/8" grove pulley). Now I am setup for modern 3/8" belt size and have an extra grove on the balancer for future needs. And, I can use a standard alternator. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | first stop for me would be a local auto electric shop
Bill | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Jim Carter has them,I put one on my 52 5 years ago.Also you'll need a in line diode on the exsiter wire from you're key switch to the alt. if you install a 2 wire alt.so the power only flows from you're switch to the alt. and not back to the switch after you turn the truck off .You can get one from a radio shack or jim carter has them to.
Pete | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Use the pulley from the generator on the alternator. A bit smaller diameter pulley would be better but the one from the generator will work fine until you find something better. | | | | | Joined: Oct 2012 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 58 | Want to sell the generator? I'm looking to switch from a 6 to 12 volt one. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 |
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I believe a good automotive electric shop can re-wind a 6 volt generator for 12 volts. | | |
