1 members (baldeagle),
95
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Has any body done any dash cleaning or polishing with any good results? Dash has 40 years of dirt ,grease,beer spray ,mayo slobber on it. I do not want to take the brown paint off cleaning it with to harsh of cleaners or polish .HELP. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Start by cleaning it with a mild soap and water. If it looks like enough paint is there, clean it up with a wax like Turtle Wax Car Wax. Start with a small area in the corner, scrub it a little with the Turtle Wax, wipe clean and see how it looks. If you really want it to pop, follow that up with a high quality wax. Right now I'm using some 3M stuff that is really nice. It's making some 20 year old dragster body panels look real nice. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I'd try a good wax and greece remover first. I'm amazed at the grime that it lifts. Use it on cabinets, stove tops, and the like all the time.
| | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | THANK YOU for the info i did not want it to rub the paint off while i did the elbow grease thing! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Believe it or not CLR and a ScotchBrite pad works great, but you need to test it on a small area. I bet it would work really well, I did the whole outside of my truck to bring out the original patina, but there isn't a lot of paint left in spots. Still, where there is paint it took off all the oxidation! | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | ^ dilute the CLR to meet your needs and use a mild ScotchBrite pad or sponge if it's just light oxidation.
I did the exterior of my truck w CLR and ScotchBrite too. It worked very well. Didn't damage any of the original paint. | | |
