5 members (Johnny Rib, Otto Skorzeny, dwreills, Wickedbass, TooMany2count), 114 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#928903 03/20/2013 6:29 AM
b10
Offline
Has any body done any dash cleaning or polishing with any good results? Dash has 40 years of dirt ,grease,beer spray ,mayo slobber on it. I do not want to take the brown paint off cleaning it with to harsh of cleaners or polish .HELP.
Start by cleaning it with a mild soap and water. If it looks like enough paint is there, clean it up with a wax like Turtle Wax Car Wax. Start with a small area in the corner, scrub it a little with the Turtle Wax, wipe clean and see how it looks. If you really want it to pop, follow that up with a high quality wax. Right now I'm using some 3M stuff that is really nice. It's making some 20 year old dragster body panels look real nice.
I'd try a good wax and greece remover first. I'm amazed at the grime that it lifts. Use it on cabinets, stove tops, and the like all the time.
Give me ambiguity
or give me something else
b10
Offline
THANK YOU for the info i did not want it to rub the paint off while i did the elbow grease thing!
Believe it or not CLR and a ScotchBrite pad works great, but you need to test it on a small area. I bet it would work really well, I did the whole outside of my truck to bring out the original patina, but there isn't a lot of paint left in spots. Still, where there is paint it took off all the oxidation!
My 46 GMC on Photobucket
^ dilute the CLR to meet your needs and use a mild ScotchBrite pad or sponge if it's just light oxidation.
I did the exterior of my truck w CLR and ScotchBrite too. It worked very well. Didn't damage any of the original paint.
Moderated by  ndkid275, Phak1
