Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Wickedbass, Wally / Montana, TexasA&M48Truck, FAST55, Chester2392, JW51, 68ironhead), 50 guests, and 4 robots.
Topics128,010
Posts1,055,298
Members48,419
#932739 04/03/2013 5:46 PM
Getting ready to replace the plug wires on my 216. Anybody tried NAPA #BEL700165? Do they fit good? Any other suggestions would be appreciated.
Ed
Forty9 #932742 04/03/2013 6:05 PM
Riding in the Passing Lane
I don't know about that particular number but I have found the wires for these old 6's are usually too long to look right. I cut some of them back to get a cleaner look.
1972 Chevy c10 Cheyenne Super
Forty9 #932862 04/04/2013 3:22 AM
Don't know bout the ones from NAPA but the ones from
Chevy Duty seem to be just about right:
http://www.pbase.com/dennygraham/image/136994197
Denny G
Denny G
Sandwich, IL
Forty9 #932877 04/04/2013 8:09 AM
b10 Offline
When i did betsy i went to napa purchased wire off the roll,boots and wire ends.I did each one from front to back. napa still had wire on the roll like i used when i was a kid .I think it cost $16.00 they work fine.
Forty9 #932879 04/04/2013 8:11 AM
The Napa wires BEL 700165 will be a universal six cylinder wire set that you will cut to length and then put on the distributor end pieces. Should have wire in the middle rather than the graphite core most newer sets have.
They will a rubber spark plug boot on the plug end of the wire.
The coil wire you will cut to fit also.
Forty9 #932909 04/04/2013 11:08 AM
As most of you probably know, the wires that Denny shows (from Classic Parts, née Chevy Duty) do not have the rubber boots at the spark plugs. In 1954 and later, boots were used (I do not know about 1953, I'll check).
Forty9 #932910 04/04/2013 11:11 AM
