4 members (walter74, SWEET, Jerry 53, 68ironhead), 88 guests, and 3 robots.
Topics128,094
Posts1,056,489
Members48,444
I bought one of those cheap chinese turn signals for my 54 chevy truck. I bought some 2 wire tail lights to use with it. The wiring diagram that came with it did not show anythinmg about the tail lights, only blinker and brake. they both work good, my question is how does everyone else wire for the tailights? Just run a wire from the headight power to the tailights?
[Linked Image from i1188.photobucket.com]
follow the shop manual wiring diagram
Sorry about that BIll.
Not to hijack, but it looks like the stop light feed wire is nat/white color. Would that likely be the same on a 49 ?.. I'm about ready to install a third brake light.
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
yes, some early diagrams didn't note colors, so best to go with the later diagram, the colors became 'industry standard' sometime mid-50's - most diagrams available here
Thanks Bill. I looked at the 49 diagram...no colors mentioned...the 50 shows a wire...Nat...coming from stop switch. I'm pretty sure mine has been retired so who knows unless an entire new harness was used with the proper colors.
The diagram also shows connectors....are these unplugable ? Would make it a cleaner install for a third brake lite and easier to test.
Mark
1949 Chevy 1/2-Ton
Lucielle
yes, where the diagrams have symbols labeled 'connector' they're the plug in ones, where they show solid dots it's junctions/terminals .... I think any replacement harness will be correct standardized colors
Super...that should make it easier....I think I already have a plug type splitter in my box of stuff wink
Mark
1949 Chevy 1/2-Ton
Lucielle
I've got it figured out, thanks guys
