1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93176 10/16/2005 10:55 PM | Joined: Apr 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 37 | Well I went to start my truck for the first since I've owned it, going over everything before that iniatial excitement of hearing your baby run for the first time.
No such luck, the starter would barely turn the engine over. Before you ask, I have checked everthing...
. battery is good .engine turns over freely by hand .thought starter must be binding...bushing gone etc. .took start off, connected charger, pushed down peddal....starter turns fast and freely.
While the starter is turning over freely with the charger, you can grab the gear with your hand and make it come to a complete stop. I'm amazed that it even had enough balls to turn the engine some what.
Any ideas ????
Thanks Rob | | |
#93177 10/17/2005 12:22 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | ya say its original?. so must be 6 volt..?? and just turning the starter with a battery charger probably wont have enough amps to pull much of a load. The best way is to crank it and see what kind of amps the startin is pullin to know if engine is tight, or starter is draggin. Your six volt battery charger is probably not putting out enough amps to really test the starter, but id think you couldnt stop it with your hand unless its only putting out a 6 volt trickle charge, then you probably could. Id say jump it with 12 volts to try it, it wont hurt anyting, just dont turn the lights on while jumpin. Those old 6 volt starters dont really spin (like a modern 12 volt system) anyway even if everything is good.
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#93178 10/17/2005 12:54 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Make sure your battery connections are good and your cables are large enough (double ought). If you feel heat anywhere after trying the starter, you have a bad connection there. | | |
#93179 10/17/2005 1:27 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ezhaulin41,
How did you test the battery to know "it's good"?
Stuart. | | |
#93180 10/20/2005 1:06 PM | Joined: Apr 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 37 | Thanks for all the inputs. I went and double checked everthing and replaced the battery. The old girl fired up on the first go.
Thanks again Rob | | |
